Prowl notifications and Status Pin errors in v2.4
Hello,
I just updated to v2.4 of the release and I am still facing two major issues.
My Kit:
Xboard Relay
Sensors at Pins 3 and 4 [ MC 38 Wired Door Window Sensor -- from Amazon ]
Mydooropener Code - Version 2.4
Push notifications via Prowl:
Normally Closed strategy
ISSUE 1. Prowl notifications dont work. I reduced watchdog mins to 1 instead of 5; I know for a fact that Status Pin 3 sensor works fine. So when the sensor [door] is open for more than a minute, I DO NOT get any notifications pushed through from Arduino to whererever [ i.e.Prowl app in my iphone]. I also changed this back to 5, still no notifications ??
ISSUE 2:
I ocasionally check the xml output by going to internet explorer browser and typing the myrouterip:portnumber. I do get the correct status for Pin 3, but I started noticing that in v2.4, Pin 4 us not being displayed. Instead its Pin 0, and its status is ALWAYS OPENED. ???? I am not sure why this is like this.
<myDoorOpener>
<status statusPin="3">Opened</status>
<status statusPin="0">Opened</status>
<challengeToken>Cyber1599094</challengeToken>
</myDoorOpener>
Can someone point me in the right direction. Other than these two, I am able to trigger BOTH relays from my iphone and everything seems OK.
Thanks in advance.
Regards,
NOTE:
I had only one issue while on v2.3 [prowl notis wold not work]. When I went to IE browser and typed, http://myrouterip:portnum, i used to get correct status for both Pins 3 and 4, like it should.
My Kit:
Xboard Relay
ISSUE 2:
<myDoorOpener>
</myDoorOpener>
Thanks in advance.
Regards,
NOTE:
