I have updated to the new v2.4 code and have the following to report;
Door Relays work with the App, I can open/close. Door status in the App shows correctly(Door is opened or Closed).
XML using the IP/PORT shows the correct Opened/Closed status. (of note, even though my door sensors are normally closed, I had to toggle them to 'Normally Opened' in the sketch for them to report correctly).
Issues:
NO Notifications work at all.
Prowl - I have the API configured, it is the correct API Key and I have tested it from the Prowl website to confirm that the notifications reach my phone but nothing sends from the Sketch.
Email - I think this isn't working because I have been unable to locate an SMTP that does not require a username/password, SSL enabled, etc. and the Sketch doesn't have anywhere that I can see to enter that type of information.
SMS - Since I cannot get a working SMTP this isn't going to work.
I ran the Debug for the Push and see the below, it looks like it is working but I never receive anything(xxxx Key for safety, it is a valid key):
*** Push - server name: 'api.prowlapp.com' - apiKey: '89xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx4ce80cc8' - subject: 'MyDoorOpener Notification' - body: 'A door or device has just been opened.' ***
*** Push - connection established ***
*** Push - connection stopped ***
*** Push - completed ***
I ran the Debug for the Notifications and see the below, I re-checked that all of the notifications options in the Sketch are un-commented and should be active.
*** open notification handler - detected an opened device/door @ pin #3 ***
*** open notification handler - NOT sending notification ***
*** open notification handler - detected an opened device/door @ pin #4 ***
When I compile I see the following errors, doesn't stop it from completing the compile but they are there:
MyDoorOpener.ino:67: warning: deprecated conversion from string constant to 'char*'
MyDoorOpener.ino: In function 'void notifyViaPush(const char*, const char*)':
MyDoorOpener.ino:260: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:263: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:265: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:266: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:270: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:275: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:280: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:282: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:285: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:286: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:287: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:288: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino: In function 'void notifyViaEmail(const String&, const String&, const String&)':
MyDoorOpener.ino:336: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:338: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:339: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:341: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:344: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:346: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:352: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:353: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:355: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:356: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:358: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino: In function 'void watchDogNotificationsHandler()':
MyDoorOpener.ino:461: warning: comparison between signed and unsigned integer expressions
MyDoorOpener.ino:473: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:475: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:481: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:505: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino: In function 'void openNotificationsHandler()':
MyDoorOpener.ino:538: warning: comparison between signed and unsigned integer expressions
MyDoorOpener.ino:543: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:545: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:551: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino:574: warning: only initialized variables can be placed into program memory area
MyDoorOpener.ino: In function 'void setup()':
MyDoorOpener.ino:607: warning: comparison between signed and unsigned integer expressions
MyDoorOpener.ino:610: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp: In constructor 'MyDoorOpenerServer::MyDoorOpenerServer(char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*)':
MyDoorOpenerServer.cpp:24: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp:27: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp:32: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp:38: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp: In member function 'void MyDoorOpenerServer::setup(unsigned char*, int)':
MyDoorOpenerServer.cpp:47: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp: In member function 'void MyDoorOpenerServer::extractRequestParams(char*, char*, char*)':
MyDoorOpenerServer.cpp:199: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp: In member function 'boolean MyDoorOpenerServer::isPasswordValid(char*)':
MyDoorOpenerServer.cpp:294: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp:326: warning: comparison between signed and unsigned integer expressions
MyDoorOpenerServer.cpp: In member function 'void MyDoorOpenerServer::writeResponse()':
MyDoorOpenerServer.cpp:355: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:356: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:357: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:358: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:362: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:363: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:369: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:371: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:376: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:381: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:383: warning: deprecated conversion from string constant to 'char*'
MyDoorOpenerServer.cpp:387: warning: deprecated conversion from string constant to 'char*'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\wiring.c:264:3: warning: #warning Timer 2 not finished (may not be present on this CPU)
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\wiring.c:273:3: warning: #warning Timer 2 not finished (may not be present on this CPU)
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_25()':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:153: warning: unused variable 'c'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HID.cpp: In member function 'virtual size_t Keyboard_::write(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HID.cpp:514: warning: unused variable 'r'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Stream.cpp: In member function 'bool Stream::find(char*)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Stream.cpp:78: warning: deprecated conversion from string constant to 'char*'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Tone.cpp:210:12: warning: #warning this may not be correct
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Tone.cpp:110: warning: only initialized variables can be placed into program memory area
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\USBCore.cpp: In function 'int USB_Send(u8, const void*, int)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\USBCore.cpp:278: warning: unused variable 'zero
Thank you for your help! I have the relays working, the sensors working, if I can get the notifications working I will be complete.
Patrick
