by support » Sun Oct 13, 2013 12:39 pm
Nothing has changed between version 2.x and 3.0 in terms of communications with the Arduino. If you were
able to open/close a door/device before, you should still be able to do it with this new release.
Rather than trying to figure out how to rollback to version 2.x, I strongly suggest you instead try to figure out
why it's not working in version 3.0.
I think that you probably have either one of the following issues (or both?) :
1) your password in the iPhone app doesn't match the one in the INO Arduino file. Status will work even if a wrong
password is used because it's not password protected. Opening and closing will require a valid password though.
2) your device's RELAY pin in the iPhone app doesn't match the one in the INO Arduino file.
Make sure of the above and try again. It should work !
Keep us posted on your results.
