Arduino uno and Ethernet shield
Ethernet shield hardware related questions and discussions (including WiFi shields, etc).
Postby Luckyman » Fri Mar 13, 2015 1:22 am
Hi sir, If I want to use Arduino uno and Ethernet shield, do I have to modify code? And how do I wiring relay and board?
Thank
Luckyman
Re: Arduino uno and Ethernet shield
Postby support » Sun Mar 15, 2015 9:49 am
Code should work as-is without changes, even when using a Uno. You might want to check at our
older instructions PDF which uses hardware which is somewhat closer to your setup. The links to
our previous versions of the instructions PDF can be found in the current version of the PDF,
in the Intro if I recall ...
Return to Ethernet Shields
