Hi, I have been using MyDooropener for a couple of years with Ether 10 card and it works well.
I have just bought an XBoard v3 and got it loaded with the code you supply and it seems to work ok only the first time I command a switching activity. The application requires that each relay on the XBoard when switched is required to stay closed for 30 seconds. I can achieve this ok by setting the "define relay delay" to 30000 but it seems that once I switch the relay remotely for the first time the App on my phone loses communication with the board and won't get it back. The way to resolve this is to shut the App down completely and re start it. I'm wondering if there is something else I need to change in my sketch to allow the "relay delay" setting to work or should I be looking else ware to resolve my problem. do I for example have to have the refresh rates the same for all the two controllers I'm running maybe? Both the ether10 and the XBoard are on the same network.
