MyDoorOpener - Compile Error
DFRobot XBoard Relay related questions and discussions.
Postby tiga31328 » Mon Dec 15, 2014 11:51 pm
I searched the forms and saw the directory structure comments, I have verified that my files are in the correct directory structure in my Windows 8.1 system.
Setting only my basic settings, IP and Password I receive the following errors after I 'Save' and do a Sketch|Verify|Compile?
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Leonardo"
MyDoorOpenerServer.cpp: In member function 'boolean MyDoorOpenerServer::isPasswordValid(char*)':
MyDoorOpenerServer.cpp:311: error: 'aes256_context' was not declared in this scope
MyDoorOpenerServer.cpp:311: error: expected `;' before 'ctx'
MyDoorOpenerServer.cpp:312: error: 'ctx' was not declared in this scope
MyDoorOpenerServer.cpp:312: error: 'aes256_init' was not declared in this scope
MyDoorOpenerServer.cpp:313: error: 'aes256_decrypt_ecb' was not declared in this scope
MyDoorOpenerServer.cpp:314: error: 'aes256_done' was not declared in this scope
Any help is greatly appreciated.
Thank you,
Patrick
tiga31328
Re: MyDoorOpener - Compile Error
Postby xamos1 » Tue Dec 30, 2014 3:48 pm
Try installing an Example Ethernet Web Server Sketch and see if it would load. Thats what i did.
xamos1
Postby support » Tue Dec 30, 2014 6:38 pm
Good point xamos1. Also, make sure you're using v2.3 of our Arduino backend code as v2.4 is still
under works and known to have some issues with status sensing.
Postby support » Tue Jan 20, 2015 8:26 pm
Follow-up in case someone gets to this thread directly. v2.4 is now fully functional.
Return to DFRobot XBoard Relay
