Arduino stops responding after a week or so...
Postby PaulWatkins » Sun Sep 08, 2013 9:44 am
My Arduino stops responding to the iPhone app after a week or so of continuous operation. If I reboot the Arduino (pull the power out) everything is fine. Unfortunately, the times I need to remotely open the garage door for somebody is usually when the Arduino has stopped responding. Any ideas?
PaulWatkins
Re: Arduino stops responding after a week or so...
Postby support » Mon Sep 09, 2013 9:33 am
Hi Paul,
I never heard of such problem except with people with defective hardware. Are you using a "genuine" Arduino, Ethernet
shield and DFRobot RelayShield ? I know some clones exist out there and I've heard they can give you unexpected/intermittent
issues at times.
Also, have you had a chance to try with another Arduino board, as you might have a defective device ?
I've had my personal setup running for ever. The only time it gets shut down is when there's a power outage at my
house. It then recycles itself when the power comes back ON. It does so, on its own, and comes back up online without
any human intervention.
Postby ToddG » Mon Sep 09, 2013 11:24 am
Hi Paul,
I am by no means an expert at Ardunio, but I figured I would toss out a couple of ideas for you to mull over- My guess is your device is just hanging or losing connection with the router somehow. I have not had any problems with my setup.
1. Perhaps program in a timer to send you a status email/txt/push. This could do two things- Notify you everything is still working, and perhaps keep the connection alive.
2. You could also program in a nightly reset using a simple reset function. I believe one exists for Ardunio.
Good luck.
Todd-
ToddG
Postby Aadams1278 » Wed Oct 09, 2013 3:40 pm
I have been having this same issue. Unfortunately I am not using a genuine arduino board or the dfrobot relay shield. I had concerns that this may be the issue. I guess eventually I may decide to switch it out to a genuine board if it continues to happen.
Aadams1278
Postby Aadams1278 » Tue Apr 15, 2014 11:20 am
Update:
After the above post, I ended up switching out my power supply and I have not had the issue at all since then. I was using a cheap 12v wall wart and switched to a 6v name brand wall wart. I suspect it was somehow overloading the voltage regulator on the arduino. Not sure if it's a non genuine arduino issue or just a voltage issue. But anyway the problem is solved now.
Aadams1278
Postby support » Mon Apr 21, 2014 8:08 am
Thanks for sharing the solution to your problem. I'm sure it'll benefit others. Thanks!
Postby roads » Sat Jun 27, 2015 3:41 am
Same here but my Robot Relay board stops working after a couple of days. Will try another power source.
roads
Postby roads » Thu Oct 01, 2015 1:21 pm
Which one? I can only find chinese crap. Tried the robot relay shield on POE but it doesn’t work.
roads
Postby support » Sat Oct 03, 2015 10:10 am
I believe POE requires a router/switch to emit power over the network. Not all routers/switches are POE enabled. That might
explain why POE isn't working for you, unless you're sure your router/switch is POE enabled?
Postby Aadams1278 » Sat Oct 03, 2015 12:38 pm
Also some relays require their own power (more strength) to actuate the relay. I have 2 relay shields and one will operate from just the arduino power while the other requires its own power source.
Aadams1278
