Trouble with triggering
Postby fireemt538 » Thu Sep 05, 2013 9:18 pm
Hi all, wondering if anyone might be able to help me before I go nuts.
I can't get the digitalpins to fire the relays.
Here's what I've got:
Arduino Uno R3
Ethernet Shield
Relay shield w/ 4 relays
MyDoorOpener Elite on my IPhone (setup with correct password, status pins, digital pins, ect...)
I think I've followed the directions to a tee several times and still won't work. This is the first time I've ever messed with arduino boards and shields. I've replaced all 3 units thinking one might be fried.
I found some code to check the relay shield so I uploaded it and it cycled the relays one at a time and they all worked, so I reuploaded mydooropener code and it won't work.
However I do have the status sensors hooked up and working on the app, It just won't open and close my garage door. I have low volt wires run from com1 and no1, com2 and no2, com3 and no3 to the remote on the wall like as described. My app is set up with my dyndns and port forwarding. I can see the arduino from the internet in a web browser. It does the same thing if I hook straight to my LAN.
Any help appreciated,
David
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<myDoorOpener>
<status statusPin="2">Closed</status>
<status statusPin="3">Closed</status>
<challengeToken>Cyber04146</challengeToken>
</myDoorOpener>
Here is my code:
// Copyright (C) 2009 - 2012, MyDoorOpener.com
// Release Notes:
// v1.0 [02/23/2010] - Initial release
// v1.1 [03/02/2010] - Added support for up to three garage doors.
// v1.2 [08/11/2010] - Deprecated HTTP POST in favor of HTTP GET parameters.
// - Added additional serial debugging.
// v2.0 [05/11/2012] - Updated to support unlimited number of devices (used to be max 3).
// - Updated to support Arduino v1.0 IDE.
// v2.2 [12/15/2012] - Updated to support SMTP email notifications
// - Updated to support SMS notifications (via carrier provided SMTPtoSMS gateway)
// - Updated to support iOS push notifications (via Prowl)
// - Added logic to support multiple status reading strategies (3v5v, NC, NO, etc)
// - Relocated most string literals to flash memory
// - Certified compatibility with ArduinoEthernet (all-in-one) and DFRobot RelayShield hardware
// - Certified compatibility with Arduino v1.0.3 IDE
//#define MYDOOROPENER_SERIAL_DEBUGGING 1
//#define WEBDUINO_SERIAL_DEBUGGING 1
//#define NOTIFICATIONS_SERIAL_DEBUGGING 1
//#define SMTP_SERIAL_DEBUGGING 1
//#define PUSH_SERIAL_DEBUGGING 1
#include <Arduino.h>
#include <WebServer.h>
static const uint8_t ip[4] = { 192, 168, 0, 101 };
// password required for operating door [max length = 16] (status fetching doesn't require password). This
#define PASSWORD "door"
// Device/Door configuration (relais and sensors)
//static const uint8_t relayPins[] = { 9 }; // single device at pin #9
static uint8_t relayPins[] = { 2, 3, 4, }; // select if using DFRobot RelayShield
//static uint8_t relayPins[] = { 2, 3, 4 }; // even more devices at pins #2, #3, #4, etc ...
//static const uint8_t statusPins[] = { 3 }; // single device at pin #3
static uint8_t statusPins[] = { 2, 3, 4, }; // select if using DFRobot RelayShield
//#define STATUS_STRATEGY_3VCLOSED_5VOPENED // initial approach - uses analogRead combined with STATUS_OPEN_TRESHOLD (opened == +5v, closed == +3v)
#define STATUS_STRATEGY_NORMALLY_CLOSED // classic door sensor - uses digitalRead to interpret door/device status (opened == high-impedance, closed == GND)
//#define STATUS_STRATEGY_NORMALLY_OPENED // alternate approach - uses digitalRead to interpret door/device status (opened == GND, closed == high-impedance)
//#define NOTIFICATIONS_WATCHDOG_MINUTES 5
//#define PUSH_NOTIFICATIONS
static const char prowlApiKey[] = "paste-your-prowl-provided-api-key-here";
static const char prowlServerName[] = "api.prowlapp.com";
static const int prowlServerPort = 80;
static const char prowlApiBaseUrl[] = "/publicapi/add";
// if defined, will fire notifications using SMS notifications (uncomment to turn ON - rember to adjust SMTP settings too)
#define SMS_NOTIFICATIONS
static const char smtpToForSms[] = "************@txt.att.net";
#define SMTP_NOTIFICATIONS
static const char smtpServerName[] = "**********@mobile.att.net";
// set to your ISP's SMTP server port (typically port 25)
static const int smtpServerPort = 25;
static const char smtpToForEmail[] = "***********@txt.att.net";
// Misc configuration constants (should not require any changes)
// EthernetShield MAC address.
static uint8_t mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Arduino HTTP server listening port number.
WebServer webserver("", 8080);
// number of milliseconds relay pin will be held high when triggered.
#define RELAY_DELAY 1000
// misc size constants
#define HTTP_PARAM_NAME_SIZE 16
#define HTTP_PARAM_VALUE_SIZE 64
#define PASSWORD_HEX_SIZE 32
#define PASSWORD_SIZE 16
#define AES256_CRYPTO_KEY_SIZE 32
#define CHALLENGE_TOKEN_SIZE 16
void getUrlEncoded(const char* msg, char* encodedMsg)
const char hex[] = "0123456789abcdef";
while(*msg != '\0')
if(('a' <= *msg && *msg <= 'z') || ('A' <= *msg && *msg <= 'Z') || ('0' <= *msg && *msg <= '9'))
*encodedMsg = *msg;
encodedMsg++;
*encodedMsg = '%';
encodedMsg++;
*encodedMsg = hex[*msg >> 4];
encodedMsg++;
*encodedMsg = hex[*msg & 15];
encodedMsg++;
msg++;
EthernetClient pushClient;
void notifyViaPush(const char* subject, const char* body)
Serial.print(F("*** Push - server name: '"));
Serial.print(prowlServerName);
Serial.print(F("' - "));
Serial.print(F("apiKey: '"));
Serial.print(prowlApiKey);
Serial.print(F("subject: '"));
Serial.print(subject);
Serial.print(F("body: '"));
Serial.print(body);
pushClient.print(F("&url=mydooropener%3A%2F%2Fstatus"));
Serial.println(F("*** Push - completed ***"));
EthernetClient smtpClient;
void notifyViaEmail(const String& to, const String& subject, const String& body)
#if defined(SMTP_SERIAL_DEBUGGING)
Serial.print(F("*** SMTP - server name: '"));
Serial.print(smtpServerName);
Serial.print(F("to: '"));
Serial.print(to);
Serial.print(body);
if (smtpClient.connect(smtpServerName, smtpServerPort))
Serial.println(F("*** SMTP - connection established ***"));
smtpClient.println(F("HELO relai.mydooropener.com"));
smtpClient.print(F("MAIL FROM:"));
smtpClient.println(F("noreply@mydooropener.com"));
smtpClient.print(F("RCPT TO:"));
smtpClient.println(to);
smtpClient.println(F("DATA"));
smtpClient.print(F("SUBJECT: "));
smtpClient.println(subject);
smtpClient.println();
smtpClient.print(body);
smtpClient.print(F(" "));
smtpClient.println(F("mydooropener://status"));
smtpClient.println(F("."));
smtpClient.println(F("QUIT"));
smtpClient.stop();
Serial.println(F("*** SMTP - connection stopped ***"));
Serial.println(F("*** SMTP - completed ***"));
void notifyViaEmail(const char* subject, const char* body)
notifyViaEmail(smtpToForEmail, subject, body);
void notifyViaSms(const char* subject, const char* body)
notifyViaEmail(smtpToForSms, subject, body);
pinMode(pinNumber+14, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
Serial.print(F("*** isOpen - status value for pin: '"));
Serial.print(pinNumber);
Serial.print(F("' is '"));
Serial.print(status);
boolean retVal = false;
retVal = status >= STATUS_OPEN_TRESHOLD;
#elif defined(STATUS_STRATEGY_5VCLOSED_3VOPENED)
retVal = status <= STATUS_OPEN_TRESHOLD;
retVal = status == LOW;
#elif defined(STATUS_STRATEGY_NORMALLY_OPENED)
retVal = status == HIGH;
Serial.print(F("' returing: '"));
void output(WebServer &server, char* data, bool newLine)
if (newLine)
Serial.println(data);
Serial.print(data);
if (newLine)
server.println(data);
server.print(data);
void output(WebServer &server, int number, bool newLine)
char str[10] = "";
itoa(number, str, 10);
output(server, str, newLine);
void webRequestHandler(WebServer &server, WebServer::ConnectionType type, char *url, bool isUrlComplete)
Serial.println(F("*** WebServerRequestHandler begin ***"));
// holder for submitted password (as hex)
char submitPassword[PASSWORD_HEX_SIZE + 1];
memset(&submitPassword, 0, sizeof(submitPassword));
// door on which open/close action is to be carried out. If unspecified, assume door #1
char relayPinAsString[10];
memset(&relayPinAsString, 0, sizeof(relayPinAsString));
int relayPin = -1;
// holder for current challenge token value. The following must not be
// initialized (memset) because it is static and must persist across HTTP calls
static char currentChallengeToken[CHALLENGE_TOKEN_SIZE + 1] = "";
// handle HTTP GET params (if provided)
char name[HTTP_PARAM_NAME_SIZE + 1];
char value[HTTP_PARAM_VALUE_SIZE + 1];
// process all HTTP GET parameters
if (type == WebServer::GET)
Serial.println(F("*** GET Request ***"));
while (url && strlen(url))
// process each HTTP GET parameter, one at a time
memset(&name, 0, sizeof(name));
memset(&value, 0, sizeof(value));
server.nextURLparam(&url, name, HTTP_PARAM_NAME_SIZE, value, HTTP_PARAM_VALUE_SIZE);
Serial.print(F("*** HTTP GET PARAM - name: '"));
Serial.print(name);
Serial.print(F("value: '"));
Serial.print(value);
// keep hold of submitted encrypted hex password value
if (strcmp(name, "password") == 0)
strcpy(submitPassword, value);
// keep hold of relay pin which should be triggered
else if (strcmp(name, "relayPin") == 0)
strcpy(relayPinAsString, value);
relayPin = atoi(relayPinAsString);
// the presence of an HTTP GET password param results in a request
// to trigger the relay (used to be triggered by an HTTP request of type POST)
if(strlen(submitPassword) > 0)
Serial.print(F("*** submitPassword: '"));
Serial.print(submitPassword);
// decrypt password using latest challenge token as cypher key
uint8_t cryptoKey[AES256_CRYPTO_KEY_SIZE + 1];
memset(&cryptoKey, 0, sizeof(cryptoKey));
for (int i = 0; i < strlen(currentChallengeToken); ++i)
cryptoKey[i] = currentChallengeToken[i];
uint8_t password[PASSWORD_SIZE + 1];
memset(&password, 0, sizeof(password));
// convert password from hex string to ascii decimal
int i = 0;
int j = 0;
while (true)
if (!submitPassword[j])
char hexValue[3] = { submitPassword[j], submitPassword[j+1], '\0' };
password[i] = (int) strtol(hexValue, NULL, 16);
i += 1;
j += 2;
// proceed with AES256 password decryption
aes256_context ctx;
aes256_init(&ctx, cryptoKey);
aes256_decrypt_ecb(&ctx, password);
aes256_done(&ctx);
char passwordAsChar[PASSWORD_SIZE + 1];
memset(&passwordAsChar, 0, sizeof(passwordAsChar));
for (int i = 0; i < sizeof(password); ++i)
passwordAsChar[i] = password[i];
Serial.print(F("*** passwordAsChar: '"));
Serial.print(passwordAsChar);
// if password matches, trigger relay
if (strcmp(passwordAsChar, PASSWORD) == 0)
Serial.println(F("*** password matched ***"));
// trigger relay pin and hold it HIGH for the appropriate number of milliseconds
if (relayPin != -1)
Serial.println(F("*** relay triggered ***"));
digitalWrite(relayPin, HIGH);
delay(RELAY_DELAY);
digitalWrite(relayPin, LOW);
// write HTTP headers
server.httpSuccess("text/xml; charset=utf-8");
Serial.println(F("*** XML output begin ***"));
// write opening XML element to output stream
output(server, "<?xml version=\"1.0\"?>", true);
output(server, "<myDoorOpener>", true);
// write current door status
output(server, "<status statusPin=\"", false);
output(server, statusPins[i], false);
output(server, "\">", false);
// write current open/close state to output stream
output(server, (char*)(isOpen(statusPins[i]) ? "Opened" : "Closed"), false);
output(server, "</status>", true);
// re-generate new challenge token
sprintf(currentChallengeToken, "Cyber%i%i%i", hour(), minute(), second());
// write challenge token to output stream
output(server, "<challengeToken>", false);
output(server, currentChallengeToken, false);
output(server, "</challengeToken>", true);
// write closing XML element to output stream
output(server, "</myDoorOpener>", true);
Serial.println(F("*** XML output end ***"));
Serial.println(F("*** WebServerRequestHandler end ***"));
void watchDogNotificationsHandler()
char subject[] = "MyDoorOpener Notification";
sprintf(body, "A door or device has been opened for more than %i minute(s).", NOTIFICATIONS_WATCHDOG_MINUTES);
// can be sent. This is done to avoid floading recipient with notifications for a same event occurrence.
void openNotificationsHandler()
Serial.print(F("*** open notification handler - detected an opened device/door @ pin #"));
Serial.println(F("*** open notification handler - sending notification ***"));
char body[] = "A door or device has just been opened.";
Serial.println(F("*** open notification handler - NOT sending notification ***"));
// if all door/devices are closed, reset notificationSent semaphore so that further notifications
#if defined(MYDOOROPENER_SERIAL_DEBUGGING) || defined(WEBDUINO_SERIAL_DEBUGGING) || defined(SMTP_SERIAL_DEBUGGING) || #defined(PUSH_SERIAL_DEBUGGING) || defined(NOTIFICATIONS_SERIAL_DEBUGGING)
Serial.begin(9600);
Serial.println(F("*** MyDoorOpener setup begin ***"));
configureStatusPin(statusPins[i]);
for (int i = 0; i < sizeof(relayPins); ++i)
pinMode(relayPins[i], OUTPUT);
digitalWrite(relayPins[i], LOW);
// set arbitrary time - used for always-changing challenge token generation
setTime(0, 0, 0, 1, 1, 2010);
Ethernet.begin(mac, ip);
webserver.setDefaultCommand(&webRequestHandler);
webserver.addCommand("", &webRequestHandler);
webserver.begin();
Serial.println(F("*** MyDoorOpener setup completed ***"));
char buffer[200];
int len = sizeof(buffer);
webserver.processConnection(buffer, &len);
fireemt538
Re: Trouble with triggering
Postby support » Thu Sep 05, 2013 10:11 pm
Few questions for you:
1) Do you hear any relays "clicking" when you trigger them from the application ?
2) When you say you get status information back to the application, is it accurate (open when door is open, closed when door is closed) ?
3) In the iPhone application, have you configured each device using the same PIN# you've configured in the INO file ?
4) What version (and brand) of the relay shield are you using ?
Not sure this will resolve your issue, but you seem to be having extra commas in both your
relayPins and statusPins definitions (after the last item, there shouldn't be any comma).
Once you change that, the XML response you get back from the server should include all
3 status pins (2, 3 and 4).
Keep us posted on the results.
Postby fireemt538 » Fri Sep 06, 2013 7:02 pm
Hi thanks for the reply,
As for your questions:
1. No, I do not get any clicking sound with the app, I did however have clicking sounds when I uploaded the test code to cycle the relays
2. Yes the status info is correct... I don't have anything hooked to pin 4 yet, just have to run wires, but 2 and 3 are accurate
3. yes status pins and relay pins are matched up with what the ino file is
4. my relay shield is a seedstudio v1.3
Started from scratch again and changed exactly what I needed to, even changed port, password, ect... and modified LAN the same... Still doing the same thing, status only, no trigger.... Here is what I got over the internet, same with LAN. Iphone app updates sensors correctly thru wifi and LTE
<myDoorOpener>
<status statusPin="4">Closed</status>
<challengeToken>Cyber0011</challengeToken>
</myDoorOpener>
<myDoorOpener>
<status statusPin="3">Opened</status>
<challengeToken>Cyber0627</challengeToken>
</myDoorOpener>
fireemt538
Postby support » Fri Sep 06, 2013 8:09 pm
It's going to be hard for us to assist because we have no hands on experience with the SeedStudio RelayShield. I
recall another support ticket that was opened a while back with that shield and the solution was to change the relays as follow:
static uint8_t relayPins[] = { 4, 5, 6, 7 }; // select if using SeeedStudio RelayShield
Not sure, this will solve your problem but it's worth a try. Remember to also update the "relay" pin for each device in the iOS app. You
can/should leave the status pins as-is, that is, as follows:
static uint8_t statusPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield and SeeedStudio RelayShield
Let us know if this solved your issue.
Postby fireemt538 » Tue Sep 10, 2013 4:35 pm
Hi, thanks for the help. You were correct about changing the relay pin numbers.... that has taken care of it. Got it workin along with the status monitoring. Now all I have to do is find out all the settings for sms notifications but i'll play with that later.......
Thanks, David
fireemt538
Re: Trouble with SMS notification to AT&T phone #
Postby clintp » Mon Nov 03, 2014 6:36 pm
I can't find the SMTP server needed to send my notifications to my cell phone on the AT&T network, which does not allow SMS forwarding.
Here is the line of code, but comments say SMTP info is needed for SMS.
static const char smtpToForSms[] = "xxxxxxxxxxx@txt.att.net";
Do I need to specify a port? Appreciate the help.
clintp
Postby support » Fri Nov 07, 2014 8:57 am
Our current SMS implementation is just an email that gets sent to a "special" SMTP server from your phone carrier
that will convert the email it receives into an SMS message. Commonly called an SMTP -> SMS Gateway. So yes,
you would need to provide both an SMTP server and port for this to work.
