I've got my setup working except for the notifications system. I think I'm close but can't get over the last hurdle.
Here's where I'm at:
xboard Relay v3
Analog sensor on A3
MyDoorOpener v2.3
The analog sensor is working in that the XML returned when I visit the url directly on the arduino web server shows open and closed accordingly. The API key for my prowl config is working as I've hit a manually constructed url and that gets back to my phone, for example:
http://api.prowlapp.com/publicapi/add?a ... r%20Opened
Also, when I pull the magnetic sensors apart, the lights on the ethernet indicators on the board flash for a few seconds as if it's attempting to send the GET request to the prowl api server.
Here's my code:
- Code: Select all
// Copyright (C) 2009 - 2012, MyDoorOpener.com
// Release Notes:
// v1.0 [02/23/2010] - Initial release
// v1.1 [03/02/2010] - Added support for up to three garage doors.
// v1.2 [08/11/2010] - Deprecated HTTP POST in favor of HTTP GET parameters.
// - Added additional serial debugging.
// v2.0 [05/11/2012] - Updated to support unlimited number of devices (used to be max 3).
// - Updated to support Arduino v1.0 IDE.
// v2.2 [12/15/2012] - Updated to support SMTP email notifications
// - Updated to support SMS notifications (via carrier provided SMTPtoSMS gateway)
// - Updated to support iOS push notifications (via Prowl)
// - Added logic to support multiple status reading strategies (3v5v, NC, NO, etc)
// - Relocated most string literals to flash memory
// - Certified compatibility with ArduinoEthernet (all-in-one) and DFRobot RelayShield hardware
// - Certified compatibility with Arduino v1.0.3 IDE
// v2.3 [11/16/2014] - Certified compatibility with DFRobot Xboard Relay (which is now the new standard/default)
// - Certified compatibility with Arduino v1.0.6 IDE
//#define MYDOOROPENER_SERIAL_DEBUGGING 1
//#define WEBDUINO_SERIAL_DEBUGGING 1
//#define NOTIFICATIONS_SERIAL_DEBUGGING 1
//#define SMTP_SERIAL_DEBUGGING 1
#define PUSH_SERIAL_DEBUGGING 1
#include <Arduino.h>
#include <WebServer.h>
static const uint8_t ip[4] = { 192, 168, 1, 100 };
// password required for operating door [max length = 16] (status fetching doesn't require password). This
#define PASSWORD "shhhhhhh"
// Device/Door configuration (relais and sensors)
//static const uint8_t relayPins[] = { 9 }; // single device at pin #9
//static uint8_t relayPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
static uint8_t relayPins[] = { 7, 8 }; // select if using DFRobot XBoard Relay
//static const uint8_t statusPins[] = { 3 }; // single device at pin #3
//static uint8_t statusPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
static uint8_t statusPins[] = { 3 }; // select if using DFRobot XBoard Relay
// Uncomment when using XBoard Relay
#define USING_XBOARD_RELAY
//#define STATUS_STRATEGY_3VCLOSED_5VOPENED // initial approach - uses analogRead combined with STATUS_OPEN_TRESHOLD (opened == +5v, closed == +3v)
//#define STATUS_STRATEGY_NORMALLY_CLOSED // classic door sensor - uses digitalRead to interpret door/device status (opened == high-impedance, closed == GND)
#define STATUS_STRATEGY_NORMALLY_OPENED // alternate approach - uses digitalRead to interpret door/device status (opened == GND, closed == high-impedance)
#define NOTIFICATIONS_WATCHDOG_MINUTES 5
#define PUSH_NOTIFICATIONS
static const char prowlApiKey[] = "secretapikeyhere";
static const char prowlServerName[] = "api.prowlapp.com";
static const int prowlServerPort = 80;
static const char prowlApiBaseUrl[] = "/publicapi/add";
// if defined, will fire notifications using SMS notifications (uncomment to turn ON - rember to adjust SMTP settings too)
//#define SMS_NOTIFICATIONS
static const char smtpToForSms[] = "your-mobile-number@your-carrier-gateway.com";
//#define SMTP_NOTIFICATIONS
static const char smtpServerName[] = "smtp.vic.exemail.com.au";
// set to your ISP's SMTP server port (typically port 25)
static const int smtpServerPort = 25;
static const char smtpToForEmail[] = "yada@api.prowlapp.com";
// Misc configuration constants (should not require any changes)
// EthernetShield MAC address.
static uint8_t mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Arduino HTTP server listening port number.
WebServer webserver("", 80);
// number of milliseconds relay pin will be held high when triggered.
#define RELAY_DELAY 1000
// misc size constants
#define HTTP_PARAM_NAME_SIZE 16
#define HTTP_PARAM_VALUE_SIZE 64
#define PASSWORD_HEX_SIZE 32
#define PASSWORD_SIZE 16
#define AES256_CRYPTO_KEY_SIZE 32
#define CHALLENGE_TOKEN_SIZE 16
void getUrlEncoded(const char* msg, char* encodedMsg)
const char hex[] = "0123456789abcdef";
while(*msg != '\0')
if(('a' <= *msg && *msg <= 'z') || ('A' <= *msg && *msg <= 'Z') || ('0' <= *msg && *msg <= '9'))
*encodedMsg = *msg;
encodedMsg++;
*encodedMsg = '%';
encodedMsg++;
*encodedMsg = hex[*msg >> 4];
encodedMsg++;
*encodedMsg = hex[*msg & 15];
encodedMsg++;
msg++;
EthernetClient pushClient;
void notifyViaPush(const char* subject, const char* body)
Serial.print(F("*** Push - server name: '"));
Serial.print(prowlServerName);
Serial.print(F("' - "));
Serial.print(F("prowlApiBaseUrl: '"));
Serial.print(prowlApiBaseUrl);
Serial.print(F("apiKey: '"));
Serial.print(prowlApiKey);
Serial.print(F("subject: '"));
Serial.print(subject);
Serial.print(F("body: '"));
Serial.print(body);
// pushClient.print(F("&url=mydooropener%3A%2F%2Fstatus"));
Serial.println(F("*** Push - completed ***"));
EthernetClient smtpClient;
void notifyViaEmail(const String& to, const String& subject, const String& body)
#if defined(SMTP_SERIAL_DEBUGGING)
Serial.print(F("*** SMTP - server name: '"));
Serial.print(smtpServerName);
Serial.print(F("to: '"));
Serial.print(to);
Serial.print(body);
if (smtpClient.connect(smtpServerName, smtpServerPort))
Serial.println(F("*** SMTP - connection established ***"));
smtpClient.println(F("HELO relai.mydooropener.com"));
smtpClient.print(F("MAIL FROM:"));
smtpClient.println(F("noreply@mydooropener.com"));
smtpClient.print(F("RCPT TO:"));
smtpClient.println(to);
smtpClient.println(F("DATA"));
smtpClient.print(F("SUBJECT: "));
smtpClient.println(subject);
smtpClient.println();
smtpClient.print(body);
smtpClient.print(F(" "));
smtpClient.println(F("mydooropener://status"));
smtpClient.println(F("."));
smtpClient.println(F("QUIT"));
smtpClient.stop();
Serial.println(F("*** SMTP - connection stopped ***"));
Serial.println(F("*** SMTP - completed ***"));
void notifyViaEmail(const char* subject, const char* body)
notifyViaEmail(smtpToForEmail, subject, body);
void notifyViaSms(const char* subject, const char* body)
notifyViaEmail(smtpToForSms, subject, body);
#if defined(USING_XBOARD_RELAY)
pinMode(pinNumber+18, INPUT_PULLUP); // addressing analog pins as digital pins (+18)
#elif
pinMode(pinNumber+14, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
int status = digitalRead(pinNumber+18); // addressing analog pins as digital pins (+18)
#elif
Serial.print(F("*** isOpen - status value for pin: '"));
Serial.print(pinNumber);
Serial.print(F("' is '"));
Serial.print(status);
boolean retVal = false;
retVal = status >= STATUS_OPEN_TRESHOLD;
#elif defined(STATUS_STRATEGY_5VCLOSED_3VOPENED)
retVal = status <= STATUS_OPEN_TRESHOLD;
retVal = status == LOW;
#elif defined(STATUS_STRATEGY_NORMALLY_OPENED)
retVal = status == HIGH;
Serial.print(F("' returing: '"));
void output(WebServer &server, char* data, bool newLine)
if (newLine)
Serial.println(data);
Serial.print(data);
if (newLine)
server.println(data);
server.print(data);
void output(WebServer &server, int number, bool newLine)
char str[10] = "";
itoa(number, str, 10);
output(server, str, newLine);
void webRequestHandler(WebServer &server, WebServer::ConnectionType type, char *url, bool isUrlComplete)
Serial.println(F("*** WebServerRequestHandler begin ***"));
// holder for submitted password (as hex)
char submitPassword[PASSWORD_HEX_SIZE + 1];
memset(&submitPassword, 0, sizeof(submitPassword));
// door on which open/close action is to be carried out. If unspecified, assume door #1
char relayPinAsString[10];
memset(&relayPinAsString, 0, sizeof(relayPinAsString));
int relayPin = -1;
// holder for current challenge token value. The following must not be
// initialized (memset) because it is static and must persist across HTTP calls
static char currentChallengeToken[CHALLENGE_TOKEN_SIZE + 1] = "";
// handle HTTP GET params (if provided)
char name[HTTP_PARAM_NAME_SIZE + 1];
char value[HTTP_PARAM_VALUE_SIZE + 1];
// process all HTTP GET parameters
if (type == WebServer::GET)
Serial.println(F("*** GET Request ***"));
while (url && strlen(url))
// process each HTTP GET parameter, one at a time
memset(&name, 0, sizeof(name));
memset(&value, 0, sizeof(value));
server.nextURLparam(&url, name, HTTP_PARAM_NAME_SIZE, value, HTTP_PARAM_VALUE_SIZE);
Serial.print(F("*** HTTP GET PARAM - name: '"));
Serial.print(name);
Serial.print(F("value: '"));
Serial.print(value);
// keep hold of submitted encrypted hex password value
if (strcmp(name, "password") == 0)
strcpy(submitPassword, value);
// keep hold of relay pin which should be triggered
else if (strcmp(name, "relayPin") == 0)
strcpy(relayPinAsString, value);
relayPin = atoi(relayPinAsString);
// the presence of an HTTP GET password param results in a request
// to trigger the relay (used to be triggered by an HTTP request of type POST)
if(strlen(submitPassword) > 0)
Serial.print(F("*** submitPassword: '"));
Serial.print(submitPassword);
// decrypt password using latest challenge token as cypher key
uint8_t cryptoKey[AES256_CRYPTO_KEY_SIZE + 1];
memset(&cryptoKey, 0, sizeof(cryptoKey));
for (int i = 0; i < strlen(currentChallengeToken); ++i)
cryptoKey[i] = currentChallengeToken[i];
uint8_t password[PASSWORD_SIZE + 1];
memset(&password, 0, sizeof(password));
// convert password from hex string to ascii decimal
int i = 0;
int j = 0;
while (true)
if (!submitPassword[j])
char hexValue[3] = { submitPassword[j], submitPassword[j+1], '\0' };
password[i] = (int) strtol(hexValue, NULL, 16);
i += 1;
j += 2;
// proceed with AES256 password decryption
aes256_context ctx;
aes256_init(&ctx, cryptoKey);
aes256_decrypt_ecb(&ctx, password);
aes256_done(&ctx);
char passwordAsChar[PASSWORD_SIZE + 1];
memset(&passwordAsChar, 0, sizeof(passwordAsChar));
for (int i = 0; i < sizeof(password); ++i)
passwordAsChar[i] = password[i];
Serial.print(F("*** passwordAsChar: '"));
Serial.print(passwordAsChar);
// if password matches, trigger relay
if (strcmp(passwordAsChar, PASSWORD) == 0)
Serial.println(F("*** password matched ***"));
// trigger relay pin and hold it HIGH for the appropriate number of milliseconds
if (relayPin != -1)
Serial.println(F("*** relay triggered ***"));
digitalWrite(relayPin, HIGH);
delay(RELAY_DELAY);
digitalWrite(relayPin, LOW);
// write HTTP headers
server.httpSuccess("text/xml; charset=utf-8");
Serial.println(F("*** XML output begin ***"));
// write opening XML element to output stream
output(server, "<?xml version=\"1.0\"?>", true);
output(server, "<myDoorOpener>", true);
// write current door status
output(server, "<status statusPin=\"", false);
output(server, statusPins[i], false);
output(server, "\">", false);
// write current open/close state to output stream
output(server, (char*)(isOpen(statusPins[i]) ? "Opened" : "Closed"), false);
output(server, "</status>", true);
// re-generate new challenge token
sprintf(currentChallengeToken, "Cyber%i%i%i", hour(), minute(), second());
// write challenge token to output stream
output(server, "<challengeToken>", false);
output(server, currentChallengeToken, false);
output(server, "</challengeToken>", true);
// write closing XML element to output stream
output(server, "</myDoorOpener>", true);
Serial.println(F("*** XML output end ***"));
Serial.println(F("*** WebServerRequestHandler end ***"));
void watchDogNotificationsHandler()
char subject[] = "MyDoorOpener Notification";
sprintf(body, "A door or device has been opened for more than %i minute(s).", NOTIFICATIONS_WATCHDOG_MINUTES);
// can be sent. This is done to avoid floading recipient with notifications for a same event occurrence.
void openNotificationsHandler()
Serial.print(F("*** open notification handler - detected an opened device/door @ pin #"));
Serial.println(F("*** open notification handler - sending notification ***"));
char body[] = "A door or device has just been opened.";
Serial.println(F("*** open notification handler - NOT sending notification ***"));
// if all door/devices are closed, reset notificationSent semaphore so that further notifications
#if defined(MYDOOROPENER_SERIAL_DEBUGGING) || defined(WEBDUINO_SERIAL_DEBUGGING) || defined(SMTP_SERIAL_DEBUGGING) || #defined(PUSH_SERIAL_DEBUGGING) || defined(NOTIFICATIONS_SERIAL_DEBUGGING)
Serial.begin(9600);
Serial.println(F("*** MyDoorOpener setup begin ***"));
configureStatusPin(statusPins[i]);
for (int i = 0; i < sizeof(relayPins); ++i)
pinMode(relayPins[i], OUTPUT);
digitalWrite(relayPins[i], LOW);
// set arbitrary time - used for always-changing challenge token generation
setTime(0, 0, 0, 1, 1, 2010);
Ethernet.begin(mac, ip);
webserver.setDefaultCommand(&webRequestHandler);
webserver.addCommand("", &webRequestHandler);
webserver.begin();
Serial.println(F("*** MyDoorOpener setup completed ***"));
char buffer[200];
int len = sizeof(buffer);
webserver.processConnection(buffer, &len);
Hope that's enough information. Have been loving going through this process... never used an arduino board before.
Jay
