Error when verifiying
Postby jbeas5 » Mon Dec 29, 2014 6:10 pm
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Robot Control"
MyDoorOpenerServer.cpp: In member function 'boolean MyDoorOpenerServer::isPasswordValid(char*)':
MyDoorOpenerServer.cpp:311: error: 'aes256_context' was not declared in this scope
MyDoorOpenerServer.cpp:311: error: expected `;' before 'ctx'
MyDoorOpenerServer.cpp:312: error: 'ctx' was not declared in this scope
MyDoorOpenerServer.cpp:312: error: 'aes256_init' was not declared in this scope
MyDoorOpenerServer.cpp:313: error: 'aes256_decrypt_ecb' was not declared in this scope
MyDoorOpenerServer.cpp:314: error: 'aes256_done' was not declared in this scope
that is the clipboard copy, What should I do?
jbeas5
Re: Error when verifiying
Postby support » Tue Dec 30, 2014 6:39 pm
Make sure you have the library files in the appropriate folders. Also, make sure you're using v2.3 of
our Arduino backend code as v2.4 is known to have some issues with status sensing.
Postby jbeas5 » Sun Jan 04, 2015 9:20 am
Do you have a link where i down load the correct version. I did not change anything in the directory.
jbeas5
Postby jbeas5 » Sun Jan 04, 2015 11:55 am
I have the correct version.
this is the list of errors
MyDoorOpener:61: error: variable or field 'output' declared void
MyDoorOpener:61: error: 'WebServer' was not declared in this scope
MyDoorOpener:61: error: 'server' was not declared in this scope
MyDoorOpener:61: error: expected primary-expression before 'char'
MyDoorOpener:61: error: expected primary-expression before 'bool'
MyDoorOpener:62: error: variable or field 'output' declared void
MyDoorOpener:62: error: 'WebServer' was not declared in this scope
MyDoorOpener:62: error: 'server' was not declared in this scope
MyDoorOpener:62: error: expected primary-expression before 'int'
MyDoorOpener:62: error: expected primary-expression before 'bool'
MyDoorOpener:180: error: 'WebServer' does not name a type
MyDoorOpener:444: error: variable or field 'output' declared void
MyDoorOpener:444: error: 'WebServer' was not declared in this scope
MyDoorOpener:444: error: 'server' was not declared in this scope
MyDoorOpener:444: error: expected primary-expression before 'char'
MyDoorOpener:444: error: expected primary-expression before 'bool'
MyDoorOpener:460: error: variable or field 'output' declared void
MyDoorOpener:460: error: 'WebServer' was not declared in this scope
MyDoorOpener:460: error: 'server' was not declared in this scope
MyDoorOpener:460: error: expected primary-expression before 'int'
MyDoorOpener:460: error: expected primary-expression before 'bool'
MyDoorOpener:469: error: variable or field 'webRequestHandler' declared void
MyDoorOpener:469: error: 'WebServer' was not declared in this scope
MyDoorOpener:469: error: 'server' was not declared in this scope
MyDoorOpener:469: error: 'WebServer' has not been declared
MyDoorOpener:469: error: expected primary-expression before 'char'
MyDoorOpener:469: error: expected primary-expression before 'bool'
jbeas5
