Possible bug with N/O sensor and notifications (prowl)
Postby impliedodds » Wed Nov 26, 2014 4:45 am
Hi!
I think i ran into an issue. I ended up getting a N/O sensor for my config. It works fine after i un-commented #define STATUS_STRATEGY_NORMALLY_OPENED. The ios app registers open/close states correctly. However, prowl only send notifications on power cycle. Oddly, the sensor state doesn't matter. It sends "a door has been opened" and "a door has been open for x min" only on power cycle despite what position the sensor is actually in. I haven't tried any of the other notification types. I probably have a code issue, posted my config bellow.
Thanks for this great application, it's exactly what i was looking for. With your software and the X-board relay, i was up and running faster than i expected. Great work!
// Copyright (C) 2009 - 2012, MyDoorOpener.com
// Release Notes:
// v1.0 [02/23/2010] - Initial release
// v1.1 [03/02/2010] - Added support for up to three garage doors.
// v1.2 [08/11/2010] - Deprecated HTTP POST in favor of HTTP GET parameters.
//                   - Added additional serial debugging.
// v2.0 [05/11/2012] - Updated to support unlimited number of devices (used to be max 3).
//                   - Updated to support Arduino v1.0 IDE.
// v2.2 [12/15/2012] - Updated to support SMTP email notifications
//                   - Updated to support SMS notifications (via carrier provided SMTPtoSMS gateway)
//                   - Updated to support iOS push notifications (via Prowl)
//                   - Added logic to support multiple status reading strategies (3v5v, NC, NO, etc)
//                   - Relocated most string literals to flash memory
//                   - Certified compatibility with ArduinoEthernet (all-in-one) and DFRobot RelayShield hardware
//                   - Certified compatibility with Arduino v1.0.3 IDE
// v2.3 [11/16/2014] - Certified compatibility with DFRobot Xboard Relay (which is now the new standard/default)
//                   - Certified compatibility with Arduino v1.0.6 IDE
//#define MYDOOROPENER_SERIAL_DEBUGGING 1
//#define WEBDUINO_SERIAL_DEBUGGING 1
//#define NOTIFICATIONS_SERIAL_DEBUGGING 1
//#define SMTP_SERIAL_DEBUGGING 1
//#define PUSH_SERIAL_DEBUGGING 1
#include <Arduino.h>
#include <WebServer.h>
static const uint8_t ip[4] = { 10, 0, 1, 222 };
// password required for operating door [max length = 16] (status fetching doesn't require password). This
#define PASSWORD "dank604604"
// Device/Door configuration (relais and sensors)
//static const uint8_t relayPins[] = { 9 }; // single device at pin #9
//static uint8_t relayPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
static uint8_t relayPins[] = { 7, 8 }; // select if using DFRobot XBoard Relay
//static const uint8_t statusPins[] = { 3 }; // single device at pin #3
//static uint8_t statusPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
static uint8_t statusPins[] = { 3, 4 }; // select if using DFRobot XBoard Relay
// Comment if not using XBoard Relay
#define USING_XBOARD_RELAY
//#define STATUS_STRATEGY_3VCLOSED_5VOPENED // initial approach - uses analogRead combined with STATUS_OPEN_TRESHOLD (opened == +5v, closed == +3v)
//define STATUS_STRATEGY_NORMALLY_CLOSED // classic door sensor - uses digitalRead to interpret door/device status (opened == high-impedance, closed == GND)
#define STATUS_STRATEGY_NORMALLY_OPENED // alternate approach - uses digitalRead to interpret door/device status (opened == GND, closed == high-impedance)
#define NOTIFICATIONS_WATCHDOG_MINUTES  3
#define PUSH_NOTIFICATIONS
static const char prowlApiKey[] = "425c5ca45dc5ed65a0012ab7155a07f4539f0b4b";
static const char prowlServerName[] = "api.prowlapp.com";
static const int prowlServerPort = 80;
// set to Prowl API base url (typically /publicapi/add)`
static const char prowlApiBaseUrl[] = "/publicapi/add";
// if defined, will fire notifications using SMS notifications (uncomment to turn ON - rember to adjust SMTP settings too)
//#define SMS_NOTIFICATIONS
static const char smtpToForSms[] = "your-mobile-number@your-carrier-gateway.com";
//#define SMTP_NOTIFICATIONS
static const char smtpServerName[] = "smtp-server.your-isp.com";
// set to your ISP's SMTP server port (typically port 25)
static const int smtpServerPort = 25;
static const char smtpToForEmail[] = "your.address@gmail.com";
// Misc configuration constants (should not require any changes)
// EthernetShield MAC address.
static uint8_t mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Arduino HTTP server listening port number.
WebServer webserver("", 80);
// number of milliseconds relay pin will be held high when triggered.
#define RELAY_DELAY 1000
// misc size constants
#define HTTP_PARAM_NAME_SIZE 16
#define HTTP_PARAM_VALUE_SIZE 64
#define PASSWORD_HEX_SIZE 32
#define PASSWORD_SIZE 16
#define AES256_CRYPTO_KEY_SIZE 32
#define CHALLENGE_TOKEN_SIZE 16
void getUrlEncoded(const char* msg, char* encodedMsg)
  const char hex[] = "0123456789abcdef";
  while(*msg != '\0')
    if(('a' <= *msg && *msg <= 'z') || ('A' <= *msg && *msg <= 'Z') || ('0' <= *msg && *msg <= '9'))
      *encodedMsg = *msg;
      encodedMsg++;
      *encodedMsg = '%';
      encodedMsg++;
      *encodedMsg = hex[*msg >> 4];
      encodedMsg++;
      *encodedMsg = hex[*msg & 15];
      encodedMsg++;
    msg++;
EthernetClient pushClient;
void notifyViaPush(const char* subject, const char* body)
    Serial.print(F("*** Push - server name: '"));
    Serial.print(prowlServerName);
    Serial.print(F("' - "));
    Serial.print(F("apiKey: '"));
    Serial.print(prowlApiKey);
    Serial.print(F("subject: '"));
    Serial.print(subject);
    Serial.print(F("body: '"));
    Serial.print(body);
    pushClient.print(F("&url=mydooropener%3A%2F%2Fstatus"));
    Serial.println(F("*** Push - completed ***"));
EthernetClient smtpClient;
void notifyViaEmail(const String& to, const String& subject, const String& body)
  #if defined(SMTP_SERIAL_DEBUGGING)
    Serial.print(F("*** SMTP - server name: '"));
    Serial.print(smtpServerName);
    Serial.print(F("to: '"));
    Serial.print(to);
    Serial.print(body);
  if (smtpClient.connect(smtpServerName, smtpServerPort))
      Serial.println(F("*** SMTP - connection established ***"));
    smtpClient.println(F("HELO relai.mydooropener.com"));
    smtpClient.print(F("MAIL FROM:"));
    smtpClient.println(F("noreply@mydooropener.com"));
    smtpClient.print(F("RCPT TO:"));
    smtpClient.println(to);
    smtpClient.println(F("DATA"));
    smtpClient.print(F("SUBJECT: "));
    smtpClient.println(subject);
    smtpClient.println();
    smtpClient.print(body);
    smtpClient.print(F(" "));
    smtpClient.println(F("mydooropener://status"));
    smtpClient.println(F("."));
    smtpClient.println(F("QUIT"));
    smtpClient.stop();
      Serial.println(F("*** SMTP - connection stopped ***"));
    Serial.println(F("*** SMTP - completed ***"));
void notifyViaEmail(const char* subject, const char* body)
  notifyViaEmail(smtpToForEmail, subject, body);
void notifyViaSms(const char* subject, const char* body)
  notifyViaEmail(smtpToForSms, subject, body);
    #if defined(USING_XBOARD_RELAY)
      pinMode(pinNumber+18, INPUT_PULLUP); // addressing analog pins as digital pins (+18)
    #else
      pinMode(pinNumber+14, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
      int status = digitalRead(pinNumber+18); // addressing analog pins as digital pins (+18)
    #else
    Serial.print(F("*** isOpen - status value for pin: '"));
    Serial.print(pinNumber);
    Serial.print(F("' is '"));
    Serial.print(status);
  boolean retVal = false;
    retVal = status >= STATUS_OPEN_TRESHOLD;
  #elif defined(STATUS_STRATEGY_5VCLOSED_3VOPENED)
    retVal = status <= STATUS_OPEN_TRESHOLD;
    retVal = status == LOW;
  #elif defined(STATUS_STRATEGY_NORMALLY_OPENED)
    retVal = status == HIGH;
    Serial.print(F("' returing: '"));
void output(WebServer &server, char* data, bool newLine)
    if (newLine)
      Serial.println(data);
      Serial.print(data);
  if (newLine)
    server.println(data);
    server.print(data);
void output(WebServer &server, int number, bool newLine)
  char str[10] = "";
  itoa(number, str, 10);
  output(server, str, newLine);
void webRequestHandler(WebServer &server, WebServer::ConnectionType type, char *url, bool isUrlComplete)
    Serial.println(F("*** WebServerRequestHandler begin ***"));
  // holder for submitted password (as hex)
  char submitPassword[PASSWORD_HEX_SIZE + 1];
  memset(&submitPassword, 0, sizeof(submitPassword));
  // door on which open/close action is to be carried out. If unspecified, assume door #1
  char relayPinAsString[10];
  memset(&relayPinAsString, 0, sizeof(relayPinAsString));
  int relayPin = -1;
  // holder for current challenge token value. The following must not be
  // initialized (memset) because it is static and must persist across HTTP calls
  static char currentChallengeToken[CHALLENGE_TOKEN_SIZE + 1] = "";
  // handle HTTP GET params (if provided)
  char name[HTTP_PARAM_NAME_SIZE + 1];
  char value[HTTP_PARAM_VALUE_SIZE + 1];
  // process all HTTP GET parameters
  if (type == WebServer::GET)
      Serial.println(F("*** GET Request ***"));
    while (url && strlen(url))
      // process each HTTP GET parameter, one at a time
      memset(&name, 0, sizeof(name));
      memset(&value, 0, sizeof(value));
      server.nextURLparam(&url, name, HTTP_PARAM_NAME_SIZE, value, HTTP_PARAM_VALUE_SIZE);
        Serial.print(F("*** HTTP GET PARAM - name: '"));
        Serial.print(name);
        Serial.print(F("value: '"));
        Serial.print(value);
      // keep hold of submitted encrypted hex password value
      if (strcmp(name, "password") == 0)
        strcpy(submitPassword, value);
      // keep hold of relay pin which should be triggered
      else if (strcmp(name, "relayPin") == 0)
        strcpy(relayPinAsString, value);
        relayPin = atoi(relayPinAsString);
  // the presence of an HTTP GET password param results in a request
  // to trigger the relay (used to be triggered by an HTTP request of type POST)
  if(strlen(submitPassword) > 0)
      Serial.print(F("*** submitPassword: '"));
      Serial.print(submitPassword);
    // decrypt password using latest challenge token as cypher key
    uint8_t cryptoKey[AES256_CRYPTO_KEY_SIZE + 1];
    memset(&cryptoKey, 0, sizeof(cryptoKey));
    for (int i = 0; i < strlen(currentChallengeToken); ++i)
      cryptoKey[i] = currentChallengeToken[i];
    uint8_t password[PASSWORD_SIZE + 1];
    memset(&password, 0, sizeof(password));
    // convert password from hex string to ascii decimal
    int i = 0;
    int j = 0;
    while (true)
      if (!submitPassword[j])
      char hexValue[3] = { submitPassword[j], submitPassword[j+1], '\0' };
      password[i] = (int) strtol(hexValue, NULL, 16);
      i += 1;
      j += 2;
    // proceed with AES256 password decryption
    aes256_context ctx;
    aes256_init(&ctx, cryptoKey);
    aes256_decrypt_ecb(&ctx, password);
    aes256_done(&ctx);
    char passwordAsChar[PASSWORD_SIZE + 1];
    memset(&passwordAsChar, 0, sizeof(passwordAsChar));
    for (int i = 0; i < sizeof(password); ++i)
      passwordAsChar[i] = password[i];
      Serial.print(F("*** passwordAsChar: '"));
      Serial.print(passwordAsChar);
    // if password matches, trigger relay
    if (strcmp(passwordAsChar, PASSWORD) == 0)
        Serial.println(F("*** password matched ***"));
      // trigger relay pin and hold it HIGH for the appropriate number of milliseconds
      if (relayPin != -1)
          Serial.println(F("*** relay triggered ***"));
        digitalWrite(relayPin, HIGH);
        delay(RELAY_DELAY);
        digitalWrite(relayPin, LOW);
  // write HTTP headers
  server.httpSuccess("text/xml; charset=utf-8");
    Serial.println(F("*** XML output begin ***"));
  // write opening XML element to output stream
  output(server, "<?xml version=\"1.0\"?>", true);
  output(server, "<myDoorOpener>", true);
  // write current door status
    output(server, "<status statusPin=\"", false);
    output(server, statusPins[i], false);
    output(server, "\">", false);
    // write current open/close state to output stream
    output(server, (char*)(isOpen(statusPins[i]) ? "Opened" : "Closed"), false);
    output(server, "</status>", true);
  // re-generate new challenge token
  sprintf(currentChallengeToken, "Cyber%i%i%i", hour(), minute(), second());
  // write challenge token to output stream
  output(server, "<challengeToken>", false);
  output(server, currentChallengeToken, false);
  output(server, "</challengeToken>", true);
  // write closing XML element to output stream
  output(server, "</myDoorOpener>", true);
    Serial.println(F("*** XML output end ***"));
    Serial.println(F("*** WebServerRequestHandler end ***"));
void watchDogNotificationsHandler()
          char subject[] = "MyDoorOpener Notification";
          sprintf(body, "A door or device has been opened for more than %i minute(s).", NOTIFICATIONS_WATCHDOG_MINUTES);
  // can be sent. This is done to avoid floading recipient with notifications for a same event occurrence.
void openNotificationsHandler()
          Serial.print(F("*** open notification handler - detected an opened device/door @ pin #"));
          Serial.println(F("*** open notification handler - sending notification ***"));
        char body[] = "A door or device has just been opened.";
          Serial.println(F("*** open notification handler - NOT sending notification ***"));
  // if all door/devices are closed, reset notificationSent semaphore so that further notifications
  #if defined(MYDOOROPENER_SERIAL_DEBUGGING) || defined(WEBDUINO_SERIAL_DEBUGGING) || defined(SMTP_SERIAL_DEBUGGING) || #defined(PUSH_SERIAL_DEBUGGING) || defined(NOTIFICATIONS_SERIAL_DEBUGGING)
    Serial.begin(9600);
    Serial.println(F("*** MyDoorOpener setup begin ***"));
    configureStatusPin(statusPins[i]);
  for (int i = 0; i < sizeof(relayPins); ++i)
    pinMode(relayPins[i], OUTPUT);
    digitalWrite(relayPins[i], LOW);
  // set arbitrary time - used for always-changing challenge token generation
  setTime(0, 0, 0, 1, 1, 2010);
  Ethernet.begin(mac, ip);
  webserver.setDefaultCommand(&webRequestHandler);
  webserver.addCommand("", &webRequestHandler);
  webserver.begin();
    Serial.println(F("*** MyDoorOpener setup completed ***"));
  char buffer[200];
  int len = sizeof(buffer);
  webserver.processConnection(buffer, &len);
impliedodds
Re: Possible bug with N/O sensor and notifications (prowl)
Postby support » Wed Nov 26, 2014 7:20 pm
Yeah, I believe STATUS_STRATEGY_NORMALLY_CLOSED and STATUS_STRATEGY_NORMALLY_OPENED have been
inverted from the beginning. We never bothered fixing this to remain backward compatible across releases.
Happy you like the app. Please rate the App on the Apple App Store. We need those review ... Thanks!
Postby impliedodds » Thu Nov 27, 2014 5:15 am
Positive app store review incoming.
I solved my issue.
I was using pin 4 for my sensor status. So, using the default code, pin 3 was still active and reporting "open" off the bat. I just changed the code to just monitor pin 4 and everything works fine.
thanks again!
impliedodds
Postby support » Fri Nov 28, 2014 11:55 pm
Cool. Happy everything is working. Best regards,
