Unable upload
Unable upload
Postby sdandala » Sat Nov 08, 2014 11:55 am
I am using Arduino Ethernet + A000059 USB Serial converter with DFRobot Relay. I am able comply and I can not upload. The red flags are " vrdude: stk500_getsync() : not in sync: resp=0x00[/color]".
I think the computer windows 7 64 bit does not see the USB adopter as there is no Rx, Tx Green light activity.
How do I enable line # on the editor ?
I request please can someone help me.
Sudha
sdandala
Re: Unable upload
Postby support » Sun Nov 09, 2014 11:51 am
Hi!
I suggest you post Arduino support related questions to the Arduino community forum. The audience is much larger and your
chances of getting help are much higher.
Use our forums for MyDoorOpener specific related questions.
PS: Also, don't cross post your question all over our forums. That won't help! ;)
Thanks!
Re: Unable upload
Postby sdandala » Sun Nov 09, 2014 6:38 pm
I found out that one needs to use a good shielded USB cable. Probably is good ground reference issue.
Sudha
sdandala
Re: Unable upload
Postby support » Thu Nov 13, 2014 10:50 pm
Thanks for sharing the solution. Might help others!
