Problem when Verify/Compile action
Postby pablu » Mon Jul 14, 2014 7:15 am
I went though the MyDoorOpener-Instructions.pdf documentation steps (ip, password, notificaitons, etc) and I get a list of errors when compiling (please find below), even in lines I have not edited. (Original unedited MyDoorOpener.ino file gets the same error list)
Could someone tell me what I am doing wrong?
Thanks in advance
Variable or field "output" declared void
MyDoorOpener:59: error: variable or field 'output' declared void
MyDoorOpener:59: error: 'WebServer' was not declared in this scope
MyDoorOpener:59: error: 'server' was not declared in this scope
MyDoorOpener:59: error: expected primary-expression before 'char'
MyDoorOpener:59: error: expected primary-expression before 'bool'
MyDoorOpener:60: error: variable or field 'output' declared void
MyDoorOpener:60: error: 'WebServer' was not declared in this scope
MyDoorOpener:60: error: 'server' was not declared in this scope
MyDoorOpener:60: error: expected primary-expression before 'int'
MyDoorOpener:60: error: expected primary-expression before 'bool'
MyDoorOpener:173: error: 'WebServer' does not name a type
MyDoorOpener:429: error: variable or field 'output' declared void
MyDoorOpener:429: error: 'WebServer' was not declared in this scope
MyDoorOpener:429: error: 'server' was not declared in this scope
MyDoorOpener:429: error: expected primary-expression before 'char'
MyDoorOpener:429: error: expected primary-expression before 'bool'
MyDoorOpener:445: error: variable or field 'output' declared void
MyDoorOpener:445: error: 'WebServer' was not declared in this scope
MyDoorOpener:445: error: 'server' was not declared in this scope
MyDoorOpener:445: error: expected primary-expression before 'int'
MyDoorOpener:445: error: expected primary-expression before 'bool'
MyDoorOpener:454: error: variable or field 'webRequestHandler' declared void
MyDoorOpener:454: error: 'WebServer' was not declared in this scope
MyDoorOpener:454: error: 'server' was not declared in this scope
MyDoorOpener:454: error: 'WebServer' has not been declared
MyDoorOpener:454: error: expected primary-expression before 'char'
MyDoorOpener:454: error: expected primary-expression before 'bool'
pablu
Re: Problem when Verify/Compile action
Postby support » Mon Jul 14, 2014 9:26 pm
Did you search past forum posts prior to posting? Look at the following thread
which is most likely the same as what you're experiencing ...
http://forums.mydooropener.com/viewtopic.php?f=2&t=6
