Forgive me for my ignorance but even after looking through the forums I am still confused as to how I am suppose to inpu the pin layout into the IDE software.
I see the code as follows:
- Code: Select all
static const uint8_t relayPins[] = { 9 }; // single device at pin #9
//static uint8_t relayPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
static const uint8_t statusPins[] = { 3 }; // single device at pin #3
//static uint8_t statusPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
If the wiring to my door opener is connected to CO1 and NO1, and my contact sensors are connected to GND and Analog 2, do I modify the code to this?
- Code: Select all
static const uint8_t relayPins[] = { 2 }; // single device at pin #9
static const uint8_t statusPins[] = { 2 }; // single device at pin #3
