Pullup configuration
Postby tvillingett » Mon Dec 16, 2013 5:59 pm
When I tried to use a magnetic switch with built in pull-up, I had to change the code for the pull-up to work. I don't know if it is an old IDE to use +14 for pull-up?
I have earlier used PULLUP directly on the digital inputs, and it worked after removed "+14" these two places (the old code is commented).
    //pinMode(pinNumber+14, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
    pinMode(pinNumber, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
    //int status = digitalRead(pinNumber+14); // addressing analog pins as digital pins (+14)
    int status = digitalRead(pinNumber);
tvillingett
Re: Pullup configuration
Postby support » Tue Dec 17, 2013 9:18 pm
You'd typically do this to address an analog pin as a digital pin. If you don't do the +14,
you'd addressing those pins as regular analog pins instead of digital pins.
See following forum post for details: http://forum.arduino.cc/index.php?topic=28720.0
I guess it depends on what you're trying to do. If you want to address those pins using analog read,
you should instead change your STATUS STRATEGY to one of the ANALOG STRATEGY values:
When using one of the newer DIGITAL STRATEGY values ...
... it is expected that you want to read the status using a digital 0/1 read.
