I have turned on serial debugging and I see the following:
*** Push - server name: 'api.prowlapp.com' - apiKey: 'abc....' - subject: 'Garage Door OPEN Notification' - body: 'Garage Door Has been Opened!.' ***
*** Push - connection established ***
*** Push - connection stopped ***
*** Push - completed ***
- Code: Select all
#define PUSH_NOTIFICATIONS
static const char prowlApiKey[] = "my key goes here";
static const char prowlServerName[] = "api.prowlapp.com";
static const int prowlServerPort = 80;
static const char prowlApiBaseUrl[] = "/publicapi/add";
I am a bit lost here... Is there any more tracing i can turn on? Am i missing some simple here?
jr
