GEOFENCE AUTOMATION
New feature and product enhancement ideas and discussions.
Re: GEOFENCE AUTOMATION
Postby EdwardE » Mon Jul 07, 2014 10:40 am
Support,
Playing around with iBeacon/GeoFencing, using this App(https://itunes.apple.com/us/app/beecon/id822251888?mt=8), great App, has a Virtual beacon for testing. I used this sketch to trip a relay (https://github.com/openhomeautomation/CC3000_REST). I have an existing MyDoorOpener installed and running, I would like to change my URL in Beecon to call my 'MyDoorOpener' server. Above you mentioned the 'URL scheme'. Could you share an example URL, everything after the Port would be helpful?
Ed
EdwardE
Postby support » Mon Jul 07, 2014 9:34 pm
Ed,
We currently don't have any URL schemes published except the one used for notifications. This is something we'll be adding
in our next release to allow for external iOS applications to trigger actions on any of the configured MyDoorOpener
controller/devices.
Postby EdwardE » Fri Aug 08, 2014 2:33 pm
Prototyping a little Geofencing using the following:
Beacons – http://www.estimote.com
Client – http://www.beaconsandwich.com
Modified the MyDoorOpener sever to handle these URL:
To Open:
http://192.168.1.101:8002?password=xxxxxxxx&relayPin=8&iBeacon=1
To Close:
http://192.168.1.101:8002?password=xxxxxxxx&relayPin=8&iBeacon=2
Here is the workflow:
The Beacon Client sends the following Open request to my WAMP server:
http://192.168.1.100/MyDoorOpeneriBeacon.php?url=192.168.1.101:8002&request=1
The PHP script on my WAMP server sends the following to my MyDoorOpener server:
The PHP script will NOT return the resulting XML from the MyDoorOpener back to the Beacon Client (this was breaking the Beacon Client).
Not ready for 'primetime', just prototyping, it seems to work, a lot more testing, having fun. :)
Thanks…
Regards,
Ed
EdwardE
Postby support » Fri Nov 21, 2014 10:33 am
As per our post on this thread, Geofencing will not be part of our app, as it's not core to our product.
But with MyDoorOpener v3.2's addition of external application accessible URLs, you can now use applications such as Launch Center Pro
(which supports both Beacons and Geofencing), to open/close/trigger any device defined within the MyDoorOpener app.
So the use case per say is now possible.
Previous
Return to New Feature Requests
