by support » Thu Aug 29, 2013 8:19 am
Hi Bigbn,
We currently support Prowl, which is somewhat similar to Pushover. If you want, you can implement that code yourself
since notifications are purely backend and that part of the project is 100% open source.
Look at the notifyViaPush() method in the MyDoorOpener.INO file. You should be able to modify its code in order for it
to support Pushover instead of Prowl.
If you do implement it, you'd be very kind to share your code with others in the "Arduino Backend Enhancements" forum.
