I actually want my garage door to nag me when it is open for too long - that is, not only do I want a watchdog notification after some period of time, I want the system to keep bugging me over some interval until I close the garage door. Might be annoying now and then, but leaving our door open overnight would be potentially very bad...
So here is some code that seems to be working nicely:
- Code: Select all
// new "nag" code to implement repeat notifications
// if defined, will fire a repeating notification when any door/device is still open for more than the specified number of minutes
#define NOTIFICATIONS_NAG_INTERVAL 15 //NEW
void watchDogNotificationsHandler()
static time_t latestNotification = NULL; //NEW
char subject[] = "wants to tell you that";
sprintf(body, "the garage has been open for more than %i minute(s)!", NOTIFICATIONS_WATCHDOG_MINUTES);
#if defined(SMTP_NOTIFICATIONS)
latestNotification = now(); //NEW: Get the time the most recent notification was sent
//NEW: Checks where sufficient time has passed to nag, if so, then get the loop to send another notification
//Loop above will run fine because (latestOpen - initialOpen) is always greater than WATCHDOG_MINUTES
//if the door has remained open
#if defined(NOTIFICATIONS_NAG_INTERVAL)
if((latestOpen - latestNotification) > NOTIFICATIONS_NAG_INTERVAL * 60)
// can be sent. This is done to avoid floading recipient with notifications for a same event occurrence.
Your mileage may vary.
Best, Mike
