A Year in the Making...
MyDoorOpener custom/homebrew "Arduino" backend enhancements sharing and discussions.
Postby EdwardE » Mon Feb 03, 2014 12:10 pm
Almost a year ago I investigated opening and closing my garage door using my iPhone, Google and found this web site. The last year I have been reviewing Arduino hardware and software (I current have Arduino UNOs, MEGA 2560s, Yúns, SainSmart UNOs and MEGA 2560s, Adafruit Trinkets, Intel Arduino/Galileo and a Spark Core on order).
This past weekend I installed MyDoorOpener (attached code has hardware links and a link to a picture).
I had a few issues:
Whenever I Email/SMS the Web Server would stop responding, I discovered that if I manually rebooted, the Web Server began responding again (perhaps the SainSmart hardware). I added code for the Arduino Watchdog Timer (Google for details) to reboot after sending Email/SMS, worked for me.
I had to rework some of the code for the SainSmart 5V relay.
Currently MyDoorOpener is working as expected, great site, great software, thanks a lot.
Regards,
Ed
// Copyright (C) 2009 - 2012, MyDoorOpener.com
// Release Notes:
// v1.0 [02/23/2010] - Initial release
// v1.1 [03/02/2010] - Added support for up to three garage doors.
// v1.2 [08/11/2010] - Deprecated HTTP POST in favor of HTTP GET parameters.
//                   - Added additional serial debugging.
// v2.0 [05/11/2012] - Updated to support unlimited number of devices (used to be max 3).
//                   - Updated to support Arduino v1.0 IDE.
// v2.2 [12/15/2012] - Updated to support SMTP email notifications
//                   - Updated to support SMS notifications (via carrier provided SMTPtoSMS gateway)
//                   - Updated to support iOS push notifications (via Prowl)
//                   - Added logic to support multiple status reading strategies (3v5v, NC, NO, etc)
//                   - Relocated most string literals to flash memory
//                   - Certified compatibility with ArduinoEthernet (all-in-one) and DFRobot RelayShield hardware
//                   - Certified compatibility with Arduino v1.0.3 IDE
// Hardware...
//SainSmart UNO R3 + Ethernet Shield W5100
//http://www.sainsmart.com/arduino/arduino-kits/uno-r3-smartkits/sainsmart-uno-r3-improved-version-ethernet-shield-w5100-for-arduino.html
//SainSmart Sensor Shield V5 - Not required Dupont jumpers instead of soldering.
//http://www.sainsmart.com/arduino/arduino-shields/sainsmart-sensor-shield-v5-4-arduino-apc220-bluetooth-analog-module-servo-motor.html
//SainSmart 4-Channel 5V Relay Module
//http://www.sainsmart.com/4-channel-5v-relay-module-for-pic-arm-avr-dsp-arduino-msp430-ttl-logic.html
// Picture...
//http://ewenfs.dyndns.org/MyDoorOpener.JPG
//#define MYDOOROPENER_SERIAL_DEBUGGING 1
//#define WEBDUINO_SERIAL_DEBUGGING 1
//#define NOTIFICATIONS_SERIAL_DEBUGGING 1
//#define SMTP_SERIAL_DEBUGGING 1
//#define PUSH_SERIAL_DEBUGGING 1
#include <Arduino.h>
#include <WebServer.h>
#include <ComcastAccount.h>
#include <MyDoorOpener.h>
#include <avr/wdt.h>
static const uint8_t ip[4] = {
  10, 0, 0, 101 };
// password required for operating door [/* maximum */ length = 16] (status fetching doesn't require password). This
#define PASSWORD MYDOOROPENER_PASSWORD
// Device/Door configuration (relays and sensors)
static const uint8_t relayPins[] = {
  9 }; // single device at pin #9
//static uint8_t relayPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
//static uint8_t relayPins[] = { 2, 3, 4, ... }; // even more devices at pins #2, #3, #4, etc. ...
static const uint8_t statusPins[] = {
  3 }; // single device at pin #3
//static uint8_t statusPins[] = { 2, 3, 4, 5 }; // select if using DFRobot RelayShield
//static uint8_t statusPins[] = { 2, 3, 4, ... }; // even more devices at pins #2, #3, #4, etc. ...
//#define STATUS_STRATEGY_3VCLOSED_5VOPENED // initial approach - uses analogRead combined with STATUS_OPEN_TRESHOLD (opened == +5v, closed == +3v)
//#define STATUS_STRATEGY_NORMALLY_CLOSED // classic door sensor - uses digitalRead to interpret door/device status (opened == high-impedance, closed == GND)
#define STATUS_STRATEGY_NORMALLY_OPENED // alternate approach - uses digitalRead to interpret door/device status (opened == GND, closed == high-impedance)
//#define STATUS_OPEN_TRESHOLD 1000
//#define NOTIFICATIONS_WATCHDOG_MINUTES  5
//EWE - Made Global so the reboot would not loop.
static boolean notificationSent = true;
//#define PUSH_NOTIFICATIONS
static const char prowlApiKey[] = "paste-your-prowl-provided-api-key-here";
static const char prowlServerName[] = "api.prowlapp.com";
static const int prowlServerPort = 80;
static const char prowlApiBaseUrl[] = "/publicapi/add";
// SMS notifications and/or SMTP email notifications with Required Authentication
#define SMTP_AUTHENIFICATION_REQUIRED
#if defined(SMTP_AUTHENIFICATION_REQUIRED)
// set to the authorization Base64 encoded Username
static const char smtpAuthorizationUser[] = COMCAST_AUTHORIZATION_USER;
// set to the authorization Base64 encoded Password
static const char smtpAuthorizationPassword[] = COMCAST_AUTHORIZATION_PASSWORD;
// if defined, will fire notifications using SMS notifications (uncomment to turn ON - remember to adjust SMTP settings too)
#define SMS_NOTIFICATIONS
static const char smtpToForSms[] = COMCAST_SMTPTOFORSMS;
//#define SMTP_NOTIFICATIONS
static const char smtpServerName[] = "smtp.comcast.net"; //"smtpcorp.com";
//set to your ISP's SMTP server port (typically port 25)
static const int smtpServerPort = 587; //2525;
static const char smtpToForEmail[] = COMCAST_SMTPTOFOREMAIL;
EthernetClient smtpClient;
// Misc configuration constants (should not require any changes)
// EthernetShield MAC address.
static uint8_t mac[6] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Arduino HTTP server listening port number.
WebServer webserver("", 8002);
// number of milliseconds relay pin will be held high when triggered.
#define RELAY_DELAY 1000
// misc size constants
#define HTTP_PARAM_NAME_SIZE 16
#define HTTP_PARAM_VALUE_SIZE 64
#define PASSWORD_HEX_SIZE 32
#define PASSWORD_SIZE 16
#define AES256_CRYPTO_KEY_SIZE 32
#define CHALLENGE_TOKEN_SIZE 16
void getUrlEncoded(const char* msg, char* encodedMsg)
  const char hex[] = "0123456789abcdef";
  while(*msg != '\0')
    if(('a' <= *msg && *msg <= 'z') || ('A' <= *msg && *msg <= 'Z') || ('0' <= *msg && *msg <= '9'))
      *encodedMsg = *msg;
      encodedMsg++;
      *encodedMsg = '%';
      encodedMsg++;
      *encodedMsg = hex[*msg >> 4];
      encodedMsg++;
      *encodedMsg = hex[*msg & 15];
      encodedMsg++;
    msg++;
EthernetClient pushClient;
void notifyViaPush(const char* subject, const char* body)
  Serial.print(F("*** Push - server name: '"));
  Serial.print(prowlServerName);
  Serial.print(F("' - "));
  Serial.print(F("apiKey: '"));
  Serial.print(prowlApiKey);
  Serial.print(F("subject: '"));
  Serial.print(subject);
  Serial.print(F("body: '"));
  Serial.print(body);
    pushClient.print(F("&url=mydooropener%3A%2F%2Fstatus"));
  Serial.println(F("*** Push - completed ***"));
//EWE - Reworked for my Email/SMS
//EthernetClient smtpClient;
void notifyViaEmail(const String& to, const String& subject, const String& body)
#if defined(SMTP_SERIAL_DEBUGGING)
  Serial.print(F("*** SMTP - server name: '"));
  Serial.print(smtpServerName);
  Serial.print(F("to: '"));
  Serial.print(to);
  Serial.print(body);
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  delay(1000);
  Serial.println("connecting...");
  if (smtpClient.connect(smtpServerName, smtpServerPort)) {
    Serial.println("connected");
    // Make a HTTP request:
    Serial.println(F("*** SMTP - connection established ***"));
    Serial.println();
    Serial.println(F("EHLO relai.mydooropener.com"));
    smtpClient.println(F("EHLO relai.mydooropener.com"));
    if(eRcv()) {
      Serial.println();
      Serial.println(F("AUTH LOGIN"));
    smtpClient.println(F("AUTH LOGIN"));
    if(eRcv()) {
      Serial.println();
    smtpClient.println(COMCAST_AUTHORIZATION_USER);
    if(eRcv()) {
      Serial.println();
    smtpClient.println(COMCAST_AUTHORIZATION_PASSWORD);
    if(eRcv()) {
      Serial.println();
    Serial.print(F("MAIL FROM:"));
    Serial.println(F("noreply@mydooropener.com"));
    smtpClient.print(F("MAIL FROM:"));
    smtpClient.println(F("noreply@mydooropener.com"));
    if(eRcv()) {
      Serial.println();
      Serial.print(F("RCPT TO:"));
      Serial.println(to);
    smtpClient.print(F("RCPT TO:"));
    smtpClient.println(to);
    if(eRcv()) {
      Serial.println();
      Serial.println(F("DATA"));
    smtpClient.println(F("DATA"));
    if(eRcv()) {
      Serial.println();
    smtpClient.print(F("SUBJECT: "));
    smtpClient.println(subject);
    smtpClient.println();
    smtpClient.print(body);
    smtpClient.print(F(" "));
    smtpClient.println(F("mydooropener://status"));
    smtpClient.println(F(" "));
    smtpClient.println(F("."));
    Serial.println(F("."));
    if(eRcv()) {
      Serial.println();
      Serial.println(F("QUIT"));
    smtpClient.println(F("QUIT"));
    if(eRcv()) {
      Serial.println();
    smtpClient.stop();
    Serial.println(F("*** SMTP - connection stopped ***"));
    Serial.println();
    Serial.println(F("*** Watchdog Timer to restart ***"));
    //EWE - Email/SMS crashed the Web Server (may have something to do with how long it takes to Email/SMS), reboot worked for me.
    wdt_enable(WDTO_15MS); //force a reboot...
    delay(100);
    wdt_disable();
  else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  Serial.println(F("*** SMTP - completed ***"));
//EWE - Return Email/SMS responses.
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
  while(!smtpClient.available()) {
    delay(1);
    loopCount++;
    // if nothing received for 20 seconds, time out
    if(loopCount > 20000) {
      Serial.println("\r\nTimeout");
      return 0;
  while (smtpClient.available()) {
    char c = smtpClient.read();
    Serial.print(c);
  return 1;
void notifyViaEmail(const char* subject, const char* body)
  notifyViaEmail(smtpToForEmail, subject, body);
void notifyViaSms(const char* subject, const char* body)
  notifyViaEmail(smtpToForSms, subject, body);
  pinMode(pinNumber+14, INPUT_PULLUP); // addressing analog pins as digital pins (+14)
  Serial.print(F("*** isOpen - status value for pin: '"));
  Serial.print(pinNumber);
  Serial.print(F("' is '"));
  Serial.print(status);
  boolean retVal = false;
  retVal = status >= STATUS_OPEN_TRESHOLD;
#elif defined(STATUS_STRATEGY_5VCLOSED_3VOPENED)
  retVal = status <= STATUS_OPEN_TRESHOLD;
  retVal = status == LOW;
#elif defined(STATUS_STRATEGY_NORMALLY_OPENED)
  retVal = status == HIGH;
  Serial.print(F("' returing: '"));
void output(WebServer &server, char* data, bool newLine)
  if (newLine)
    Serial.println(data);
    Serial.print(data);
  if (newLine)
    server.println(data);
    server.print(data);
void output(WebServer &server, int number, bool newLine)
  char str[10] = "";
  itoa(number, str, 10);
  output(server, str, newLine);
void webRequestHandler(WebServer &server, WebServer::ConnectionType type, char *url, bool isUrlComplete)
  Serial.println(F("*** WebServerRequestHandler begin ***"));
  // holder for submitted password (as hex)
  char submitPassword[PASSWORD_HEX_SIZE + 1];
  memset(&submitPassword, 0, sizeof(submitPassword));
  // door on which open/close action is to be carried out. If unspecified, assume door #1
  char relayPinAsString[10];
  memset(&relayPinAsString, 0, sizeof(relayPinAsString));
  int relayPin = -1;
  // holder for current challenge token value. The following must not be
  // initialized (memset) because it is static and must persist across HTTP calls
  static char currentChallengeToken[CHALLENGE_TOKEN_SIZE + 1] = "";
  // handle HTTP GET params (if provided)
  char name[HTTP_PARAM_NAME_SIZE + 1];
  char value[HTTP_PARAM_VALUE_SIZE + 1];
  // process all HTTP GET parameters
  if (type == WebServer::GET)
    Serial.println(F("*** GET Request ***"));
    while (url && strlen(url))
      // process each HTTP GET parameter, one at a time
      memset(&name, 0, sizeof(name));
      memset(&value, 0, sizeof(value));
      server.nextURLparam(&url, name, HTTP_PARAM_NAME_SIZE, value, HTTP_PARAM_VALUE_SIZE);
      Serial.print(F("*** HTTP GET PARAM - name: '"));
      Serial.print(name);
      Serial.print(F("value: '"));
      Serial.print(value);
      // keep hold of submitted encrypted hex password value
      if (strcmp(name, "password") == 0)
        strcpy(submitPassword, value);
      // keep hold of relay pin which should be triggered
      else if (strcmp(name, "relayPin") == 0)
        strcpy(relayPinAsString, value);
        relayPin = atoi(relayPinAsString);
  // the presence of an HTTP GET password param results in a request
  // to trigger the relay (used to be triggered by an HTTP request of type POST)
  if(strlen(submitPassword) > 0)
    Serial.print(F("*** submitPassword: '"));
    Serial.print(submitPassword);
    // decrypt password using latest challenge token as cypher key
    uint8_t cryptoKey[AES256_CRYPTO_KEY_SIZE + 1];
    memset(&cryptoKey, 0, sizeof(cryptoKey));
    for (int i = 0; i < strlen(currentChallengeToken); ++i)
      cryptoKey[i] = currentChallengeToken[i];
    uint8_t password[PASSWORD_SIZE + 1];
    memset(&password, 0, sizeof(password));
    // convert password from hex string to ASCII decimal
    int i = 0;
    int j = 0;
    while (true)
      if (!submitPassword[j])
      char hexValue[3] = {
        submitPassword[j], submitPassword[j+1], '\0'        };
      password[i] = (int) strtol(hexValue, NULL, 16);
      i += 1;
      j += 2;
    // proceed with AES256 password decryption
    aes256_context ctx;
    aes256_init(&ctx, cryptoKey);
    aes256_decrypt_ecb(&ctx, password);
    aes256_done(&ctx);
    char passwordAsChar[PASSWORD_SIZE + 1];
    memset(&passwordAsChar, 0, sizeof(passwordAsChar));
    for (int i = 0; i < sizeof(password); ++i)
      passwordAsChar[i] = password[i];
    Serial.print(F("*** passwordAsChar: '"));
    Serial.print(passwordAsChar);
    // if password matches, trigger relay
    if (strcmp(passwordAsChar, PASSWORD) == 0)
      Serial.println(F("*** password matched ***"));
      // trigger relay pin and hold it HIGH for the appropriate number of milliseconds
      if (relayPin != -1)
        Serial.println(F("*** relay triggered ***"));
        //Working with the SainSmart 5v Relay Board - http://sainsmart.wordpress.com/tag/electronics/
        //digitalWrite(relayPin, HIGH);
        //delay(RELAY_DELAY);
        //digitalWrite(relayPin, LOW);
        delay(RELAY_DELAY);
  // write HTTP headers
  server.httpSuccess("text/xml; charset=utf-8");
  Serial.println(F("*** XML output begin ***"));
  // write opening XML element to output stream
  output(server, "<?xml version=\"1.0\"?>", true);
  output(server, "<myDoorOpener>", true);
  // write current door status
    output(server, "<status statusPin=\"", false);
    output(server, statusPins[i], false);
    output(server, "\">", false);
    // write current open/close state to output stream
    output(server, (char*)(isOpen(statusPins[i]) ? "Opened" : "Closed"), false);
    output(server, "</status>", true);
  // re-generate new challenge token
  sprintf(currentChallengeToken, "Cyber%i%i%i", hour(), minute(), second());
  // write challenge token to output stream
  output(server, "<challengeToken>", false);
  output(server, currentChallengeToken, false);
  output(server, "</challengeToken>", true);
  // write closing XML element to output stream
  output(server, "</myDoorOpener>", true);
  Serial.println(F("*** XML output end ***"));
  Serial.println(F("*** WebServerRequestHandler end ***"));
void watchDogNotificationsHandler()
          char subject[] = "MyDoorOpener Notification";
          sprintf(body, "A door or device has been opened for more than %i minute(s).", NOTIFICATIONS_WATCHDOG_MINUTES);
  // can be sent. This is done to avoid flooding recipient with notifications for a same event occurrence.
void openNotificationsHandler()
  //static boolean notificationSent = false;
      Serial.print(F("*** open notification handler - detected an opened device/door @ pin #"));
        Serial.println(F("*** open notification handler - sending notification ***"));
        char body[] = "A door or device has just been opened.";
        Serial.println(F("*** open notification handler - NOT sending notification ***"));
  // if all door/devices are closed, reset notificationSent semaphore so that further notifications
#if defined(MYDOOROPENER_SERIAL_DEBUGGING) || defined(WEBDUINO_SERIAL_DEBUGGING) || defined(SMTP_SERIAL_DEBUGGING) || #defined(PUSH_SERIAL_DEBUGGING) || defined(NOTIFICATIONS_SERIAL_DEBUGGING)
  Serial.begin(9600);
  Serial.println(F("*** MyDoorOpener setup begin ***"));
    configureStatusPin(statusPins[i]);
  for (int i = 0; i < sizeof(relayPins); ++i)
    pinMode(relayPins[i], OUTPUT);
    //digitalWrite(relayPins[i], LOW);
    digitalWrite(relayPins[i], HIGH);
  // set arbitrary time - used for always-changing challenge token generation
  setTime(0, 0, 0, 1, 1, 2010);
  webserver.setDefaultCommand(&webRequestHandler);
  webserver.addCommand("", &webRequestHandler);
  webserver.begin();
  Serial.println(F("*** MyDoorOpener setup completed ***"));
  char buffer[200];
  int len = sizeof(buffer);
  webserver.processConnection(buffer, &len);
EdwardE
Re: A Year in the Making...
Postby support » Mon Feb 03, 2014 9:31 pm
Too bad you have to reboot though ... Most probably due to SainSmart hardware ?!?
I know the SMTP authentication bit has been asked often so I'm sure it'll make
many happy users ... We never wanted to go there since there's so many variations ...
At least with these bits of code, it'll give a starting point or even a fully working
implementation for anyone who uses Comcast as their provider.
Thanks for sharing.
Return to Arduino Backend Enhancements
